Specify the icon using the ICON field.
If you follow the appropriate naming conventions for icon files, specify only the base name of the icon. The correct icon will be displayed based on the resolution and color support of your display.
Create the following icon sizes:
Actions: large, medium, and tiny
Data types: medium and tiny
The following example is an action definition for starting the Island Paint drawing tool. The icons Ipaint.l and Ipaint.s are associated with the action.
ACTION IslandPaintOpenDoc
WINDOW_TYPE NO-STDIO
ICON Ipaint
EXEC_STRING /usr/bin/IslandPaint %Arg_1"File to open:"%
If you are using color icons, the desktop first appends .pm when looking for the actual icon files. Otherwise (or if no match is found with .pm), the desktop appends .bm.
The following data type definition associates the icons comprsd.l and comprsd.s with compressed files:
DATA_ATTRIBUTES COMPRESSED
ICON comprsd ACTIONS Uncompress DESCRIPTION A COMPRESSED file has been compressed by the \ 'compress' command to take up less space.
