Additions to the application search path automatically add corresponding locations to the database, icon, and help search paths. This provides the ability to add an application server to a search path by setting only the application search path input variable.
For example, if you set DTSPSYSAPPHOSTS as follows:
export DTSPSYSAPPHOSTS=servera:
then the search paths are affected as shown in Table 9–3.
Table 9–3 Affected Search Paths|
Search Path |
Directory Added to Search Path |
Applications |
servera:/etc/dt/appconfig/appmanager/language |
Database |
servera:/etc/dt/appconfig/types/language |
Icon |
servera:/etc/dt/appconfig/icons/language |
Help |
servera:/etc/dt/appconfig/help/language |
Similarly, if you set DTSPSYSAPPHOSTS as follows:
export DTSPSYSAPPHOSTS=/projects1/apps
then the search paths are affected as shown in Table 9–4 .
Table 9–4 Affected Search Paths|
Search Path |
Applications |
/projects1/apps/appmanager/language |
Database |
/projects1/apps/types/language |
Icon |
/projects1/apps/icons/language |
Help |
/projects1/apps/help/language |
