The user can create personal controls by dropping icons on the Install Icon controls.
While this provides easy customizability, the functionality it provides is a subset of the capabilities of Front Panel controls. For example, a control created using the Install Icon control cannot:
Provide animation
Display a client window
Change appearance when an event occurs (for example, upon receiving new mail)
This section describes how to manually create Front Panel controls.
For reference information on the syntax of Front Panel controls, see the dtfpfile(4X) man page.
The structure of a Front Panel control definition is:
CONTROL control_name { TYPE control_type CONTAINER_NAME value CONTAINER_TYPE value other fields defining appearance and behavior }
The TYPE field in the control definition specifies the basic behavior of the control.
Control Behavior
The control will run a specified action when the user clicks the control or drops a file on it.
Busy light. The control blinks (toggles images) when an action is invoked
A client window in the Front Panel.
Clock.
Displays the current date.
Represents a file. Choosing the control runs the default action for the file.
This section describes the general steps for defining a control and describes how to create various types of controls.
If the control will have a PUSH_ACTION and/or DROP_ACTION, create the action definitions. These are the actions that run when the user clicks the control or drops a file on it.
Create the icon image files for the control.
For information about icon sizes, names, and locations, see Icon Image Files.
Create a new Front Panel configuration file in:
System-wide: /etc/dt/appconfig/types/language/*.fp
Personal: HomeDirectory/.dt/types/*.fp
Add the control definition to the file.
Save the file.
Choose Restart Workspace Manager from the Workspace menu.
Use these fields to define the control's behavior:
TYPE: Set to icon
PUSH_ACTION: Specifies the name of the action to be run
For example, the following control, which will be put in the Personal Applications subpanel, runs a game the user has acquired:
CONTROL Ball { TYPE icon CONTAINER_NAME PersAppsSubpanel CONTAINER_TYPE SUBPANEL ICON ball PUSH_ACTION RunBallGame HELP_STRING "Choose this control to play Ball." }
The following control will be located in the upper left corner of the switch. It starts an action named CutDisp.
CONTROL StartCutDisp { TYPE icon CONTAINER_NAME Switch CONTAINER_TYPE SWITCH POSITION_HINTS first ICON cutdisp HELP_STRING "Choose this control to run cutdisp." PUSH_ACTION CutDisp }
TYPE: Set to file
PUSH_ACTION: Set to Open
There must be an Open action defined for the data type of the file.
For example, the following control will be located on the far right side of the Main Panel. It starts Text Editor with the data file /users/ellen/PhoneList.txt. The Open action for *.txt files is part of the default action database.
CONTROL EditPhoneList { TYPE file FILE_NAME /users/ellen/PhoneList.txt CONTAINER_NAME Top CONTAINER_TYPE BOX POSITION_HINTS last ICON PhoneBook HELP_STRING "This control displays Ellen's phone list." PUSH_ACTION Open }
Use the DROP_ACTION field to specify the action that runs when the user drops a file on the control. The action must be capable of accepting a file argument.
Frequently, a control definition includes both a PUSH_ACTION and DROP_ACTION field. You can use the same action for the push and drop action.
For example, the following control, located in the Personal Applications subpanel, runs the X client xwud, which takes a file argument.
CONTROL Run_xwud { CONTAINER_NAME PerAppsSubpanel CONTAINER_TYPE SUBPANEL POSITION_HINTS 2 ICON XwudImage PUSH_ACTION RunXwud DROP_ACTION RunXwud }
TYPE: Specify one of the following values:
icon—use this type if you want to specify a PUSH_ACTION and/or DROP_ACTION for the control.
file—use this type if you want the control, when chosen, to behave like the file when the file's icon is double-clicked in File Manager.
ICON and ALTERNATE_ICON: Describe the images used to indicate the non-changed and changed state of the monitored file.
MONITOR_TYPE: Describes the conditions causing the image to change. Use one of the following values:
mail—the control will change appearance when information is added to the file.
file—the control will change when the specified file becomes non-empty.
FILE_NAME: Specifies the file to be monitored.
For example, the following control looks for the presence of a file named meetings that you expect to be transferred to your system using anonymous ftp. The control is placed at the top of the Personal Applications subpanel.
CONTROL MonitorCalendar { TYPE file CONTAINER_NAME PersonalApps CONTAINER_TYPE SUBPANEL POSITION_HINTS first FILE_NAME /users/ftp/meetings MONITOR_TYPE file ICON meetingsno ALTERNATE_ICON meetingsyes }
A one-instance control checks to see whether the process started by the PUSH_ACTION is already running. If the process is not running, the PUSH_ACTION is run. If the process is already running, the window is moved to the top of the window stack in the current workspace.
PUSH_RECALL: Set to True.
CLIENT_NAME: Specifies the name of the client to the control.
The value of CLIENT_NAME must match the first string (res_name) in the WM_CLASS property on the application's top-level window. For more information, see the xprop(1) man page.
PUSH_ACTION: Describes the action run when the user clicks the control.
For example, the following control runs one instance of an application whose action is named MyEditor.
CONTROL MyEditor { TYPE icon CONTAINER_NAME Top CONTAINER_TYPE BOX POSITION_HINTS 15 PUSH_RECALL True CLIENT_NAME BestEditor PUSH_ACTION StartMyEditor ICON MyEd }
A client window control is an application window embedded in the Front Panel. For example, you can put a system load meter in the Front Panel by creating an xload client window control.
Define the control.
TYPE: Set to client.
CLIENT_NAME: Specifies the client to be started.
Start the client from a terminal emulator command line.
For example, the following control displays a 30 × 20 pixel load meter.
CONTROL LoadMeter { TYPE client CONTAINER_NAME Top CONTAINER_TYPE BOX CLIENT_NAME xload CLIENT_GEOMETRY 30x20 }
If the client is not saved and restored between sessions, you may want to configure the control to start the client when the user clicks it. For example, you can configure the LoadMeter control to start xload by adding the following line to the definition:
PUSH_ACTION StartXload
and creating the action:
ACTION StartXload { WINDOW_TYPE NO_STDIO EXEC_STRING /usr/contrib/bin/X11/xload }
You can attach an animation sequence to be used when the user chooses the control or drops an object on it.
In order to have an animation sequence, a control must:
Be type icon
Have a PUSH_ACTION or DROP_ACTION
Specify the animation sequence using the ANIMATION component:
ANIMATION animation_name { ANIMATION icon1 [milisecond_delay] ANIMATION icon2 [milisecond_delay] … }
where icon1, icon 2, etc. are the names of icons, and milisecond_delay is the time delay between animation icons in milliseconds. The default time delay is 200 milliseconds.
Add the PUSH_ANIMATION and/or DROP_ANIMATION fields to the control definition. The value is the name of the ANIMATION sequence.
For example, the following lines animate a control that starts the BestEditor application. The time delay between icons is 300 milliseconds. The example assumes you've created icon files frame1, frame2, etc.
CONTROL BestEditor { … PUSH_ANIMATION BestEdAnimation … }
ANIMATION BestEdAnimation { frame1 300 frame2 … }
There are two ways to provide help for a control:
Providing a help string in the control definition.
The help string is displayed in the help viewer when the user invokes on-item help for the control. The help string cannot include formatting (such as headings) or links.
To provide a help string, specify it in the control definition:
HELP_STRING help_string
Specifying a help topic in a registered help volume.
A help topic is information authored using the full capabilities of the help system. Authoring a help topic requires you to use the desktop Help Developer's Kit.
To provide a help topic, specify the help volume and topic ID in the control definition:
HELP_VOLUME help_volume_name HELP_TOPIC topic_id
