Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Creating and Modifying Subpanels
Users can create and modify subpanels using the Front Panel pop-up menus.
This section discusses how to provide system-wide customization, which requires you to modify the Front Panel configuration files.
A subpanel is “attached” to a control in the Main Panel.
Figure 15–3 A subpanel's container is the control to which it is attached
Graphic
The attachment is done in the subpanel definition. The CONTAINER_NAME field specifies the control to which the subpanel is attached:
CONTROL control_name
 SUBPANEL subpanel_name
 	CONTAINER_NAME 					control_name
To Create a New System-Wide Subpanel
  1. Locate the control_name of the control in the Main Panel to which you want to attach the subpanel.
    If the control is one of the built-in controls, its definition is in /usr/dt/appconfig/types/language/dtwm.fp.
  2. Create a new file /etc/dt/appconfig/types/language/*.fp.
  3. Define the subpanel:
     		TITLE						value
     		KEYWORD				value
  4. Save the new configuration file.
  5. Choose Restart Workspace Manager from the Workspace menu.
Customizing the Built-in Subpanels
You can modify general properties (such as the title) and the contents of the built-in subpanels.
To Modify General Properties of a Built-In Subpanel
  1. Create a new Front Panel configuration file:
    • System-wide: /etc/dt/appconfig/types/language/name.fp
    • Personal: HomeDirectory/.dt/types/name.fp.
  2. Copy the entire default SUBPANEL definition from /usr/dt/appconfig/types/language/dtwm.fp to the new file:
  3. Modify the subpanel definition.
    For example, the following definition, placed in the file /users/janice/.dt/types/PerApps.fp, changes the name of the Personal Applications subpanel:
    SUBPANEL PersAppsSubpanel
     	CONTAINER_NAME					TextEditor
     	TITLE								Janice's Applications
To Add a System-Wide Control to a Built-In Subpanel
  1. Create a Front Panel configuration file /etc/dt/appconfig/types/language/name.fp.
  2. Define the system-wide control in the file.
    Use the CONTAINER_NAME and CONTAINER_TYPE fields to specify the container for the control:
     		CONTAINER_NAME					subpanel_name
     		CONTAINER_TYPE					SUBPANEL
    See Defining Front Panel Controls.
  3. Save the configuration file.
  4. Choose Restart Workspace Manager from the Workspace menu.
    For example, the following control defined in a new file /etc/dt/appconfig/types/language/DigitalClock.fp adds the DigitalClock (in the Desktop_Tools application group) to the Personal Applications subpanel for all users.
    CONTROL DigitalClockControl
     	TYPE						icon
     	CONTAINER_NAME			PersAppsSubpanel
     	ICON						Dtdgclk
     	PUSH_ACTION				DigitalClock
     	PUSH_RECALL				True
To Remove a Control from a Built-In Subpanel
    Use the same procedure as for removing a Main Panel control. See To Remove a Control.
To Remove the Install Icon Control
    Add the following field to the subpanel definition:
	CONTROL_INSTALL					False
To Change the Auto-Close Behavior of Subpanels
The default behavior of subpanels is to close when the user chooses a control, unless the user has moved the subpanel from its original position.
The Front Panel can be configured to keep subpanels open until the user explicitly closes them.
  1. Create a new Front Panel configuration file in:
    • System-wide: /etc/dt/appconfig/types/language/*.fp
    • Personal: HomeDirectory/.dt/types/*.fp
  2. Copy the default PANEL definition from /usr/dt/appconfig/types/language/dtwm.fp to the new file:
    	PANEL FrontPanel
  3. Add the following field to the PANEL definition:
    	SUBPANEL_UNPOST    False
