Use these fields to define the control's behavior:
TYPE: Set to icon
PUSH_ACTION: Specifies the name of the action to be run
For example, the following control, which will be put in the Personal Applications subpanel, runs a game the user has acquired:
CONTROL Ball
TYPE icon
CONTAINER_NAME PersAppsSubpanel
CONTAINER_TYPE SUBPANEL
ICON ball
PUSH_ACTION RunBallGame
HELP_STRING "Choose this control to play Ball."
The following control will be located in the upper left corner of the switch. It starts an action named CutDisp.
CONTROL StartCutDisp
TYPE icon
CONTAINER_NAME Switch
CONTAINER_TYPE SWITCH
POSITION_HINTS first
ICON cutdisp
HELP_STRING "Choose this control to run cutdisp."
PUSH_ACTION CutDisp
