Use these fields to define the control's behavior:
TYPE: Set to file
PUSH_ACTION: Set to Open
There must be an Open action defined for the data type of the file.
For example, the following control will be located on the far right side of the Main Panel. It starts Text Editor with the data file /users/ellen/PhoneList.txt. The Open action for *.txt files is part of the default action database.
CONTROL EditPhoneList
TYPE file
FILE_NAME /users/ellen/PhoneList.txt
CONTAINER_NAME Top
CONTAINER_TYPE BOX
POSITION_HINTS last
ICON PhoneBook
HELP_STRING "This control displays Ellen's phone list."
PUSH_ACTION Open
