Use these fields to define the control's behavior:
TYPE: Specify one of the following values:
icon—use this type if you want to specify a PUSH_ACTION and/or DROP_ACTION for the control.
file—use this type if you want the control, when chosen, to behave like the file when the file's icon is double-clicked in File Manager.
ICON and ALTERNATE_ICON: Describe the images used to indicate the non-changed and changed state of the monitored file.
MONITOR_TYPE: Describes the conditions causing the image to change. Use one of the following values:
mail—the control will change appearance when information is added to the file.
file—the control will change when the specified file becomes non-empty.
FILE_NAME: Specifies the file to be monitored.
For example, the following control looks for the presence of a file named meetings that you expect to be transferred to your system using anonymous ftp. The control is placed at the top of the Personal Applications subpanel.
CONTROL MonitorCalendar
TYPE file
CONTAINER_NAME PersonalApps
CONTAINER_TYPE SUBPANEL
POSITION_HINTS first
FILE_NAME /users/ftp/meetings
MONITOR_TYPE file
ICON meetingsno
ALTERNATE_ICON meetingsyes
