A one-instance control checks to see whether the process started by the PUSH_ACTION is already running. If the process is not running, the PUSH_ACTION is run. If the process is already running, the window is moved to the top of the window stack in the current workspace.
Use these fields to define the control's behavior:
PUSH_RECALL: Set to True.
CLIENT_NAME: Specifies the name of the client to the control.
The value of CLIENT_NAME must match the first string (res_name) in the WM_CLASS property on the application's top-level window. For more information, see the xprop(1) man page.
PUSH_ACTION: Describes the action run when the user clicks the control.
For example, the following control runs one instance of an application whose action is named MyEditor.
CONTROL MyEditor
TYPE icon
CONTAINER_NAME Top
CONTAINER_TYPE BOX
POSITION_HINTS 15
PUSH_RECALL True
CLIENT_NAME BestEditor
PUSH_ACTION StartMyEditor
ICON MyEd
