A client window control is an application window embedded in the Front Panel. For example, you can put a system load meter in the Front Panel by creating an xload client window control.
Define the control.
Use these fields to define the control's behavior:
TYPE: Set to client.
CLIENT_NAME: Specifies the client to be started.
The value of CLIENT_NAME must match the first string (res_name) in the WM_CLASS property on the application's top-level window. For more information, see the xprop(1) man page.
Choose Restart Workspace Manager from the Workspace menu.
Start the client from a terminal emulator command line.
For example, the following control displays a 30 × 20 pixel load meter.
CONTROL LoadMeter
TYPE client
CONTAINER_NAME Top
CONTAINER_TYPE BOX
CLIENT_NAME xload
CLIENT_GEOMETRY 30x20
If the client is not saved and restored between sessions, you may want to configure the control to start the client when the user clicks it. For example, you can configure the LoadMeter control to start xload by adding the following line to the definition:
PUSH_ACTION StartXload
and creating the action:
ACTION StartXload
WINDOW_TYPE NO_STDIO
EXEC_STRING /usr/contrib/bin/X11/xload
