Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Introduction to Data Types
When the user creates a new data file, the appearance and behavior of the file's icon in File Manager varies depending on the type of data file the user has created. This ability to create custom appearance and behavior for files and directories is provided by the desktop's data typing mechanism.
What Is a Data Type?
A data type is a construct that is defined within the desktop database. For example, here is the definition of the XWD data type. The definition is in the configuration file /usr/dt/appconfig/types/language/xclients.dt:
DATA_ATTRIBUTES XWD
 ACTIONS          Open,Print
 ICON             Dtxwd
 NAME_TEMPLATE    %s.xwd
 MIME_TYPE        application/octet-stream
 SUNV3_TYPE       xwd-file
 DESCRIPTION      This file contains a graphics image in the XWD \
                  format. These files are typically created by \
                  taking snapshots of windows using the XwdCapture \
                  action. Its data type is named XWD. XWD files \
                  have names ending with `.xwd' or `.wd'.
DATA_CRITERIA XWD1
 	DATA_ATTRIBUTES_NAME			XWD
 	MODE									f
 	NAME_PATTERN						*.xwd
 DATA_CRITERIA XWD2
 	MODE									f
 	NAME_PATTERN						*.wd
Every data type definition has two parts:
DATA_ATTRIBUTES—describes the appearance and behavior of the data type.
DATA_CRITERIA—specifies the rules (naming or content) for categorizing a file as belonging to that data type.
The DATA_ATTRIBUTES_NAME field connects the criteria to the attributes.
There can be multiple DATA_CRITERIA for a DATA_ATTRIBUTE. For example, the XWD data type has two criteria to specify two different naming criteria (NAME_PATTERN)—names ending with .xwd or .wd.
How Data Types Connect Data Files to Actions
Consider the XWD data type. The user creates an XWD-type file by giving the file one of two file-name suffixes (extensions): .xwd or.wd. The desktop uses the file name as the criteria for designating a file as that type.
The XWD data type supplies each file of that data type with:
Running Actions from the Selected Menu
The Selected menu in File Manager is active only when a file or directory is selected. The commands at the bottom of the Selected menu depend on the data type. For example, if an XWD file is selected, the Selected menu includes the items Open and Print.
The ACTIONS field in the data type definition specifies the commands added to the bottom of the data type's Selected menu.
DATA_ATTRIBUTES XWD { ACTIONS Open,Print … }
The contents of the Selected menu depends on the data type. However, many different data types provide an Open action—that is, when you select a file of that particular data type in File Manager and display the Selected menu, you see an Open command.
Figure 10–5 The Selected menu for an XWD file
Graphic
The Open action usually runs the application with which the data file is associated. For example, opening an XWD file runs the Xwud action, which in turn runs the xwud X client to display the screen image. In other words, for the XWD data type, the Open action is synonymous with the Xwud action. Likewise, opening a file of data type TEXTFILE runs the Text Editor, and opening a BM (bitmap) or PM (pixmap) file runs Icon Editor.
The ability to create a variety of Open actions that do different things uses two features of action definitions:
Here is the definition of the action that maps the Open action to the Xwud action for the XWD data type. It is located in the database configuration file /usr/dt/appconfig/types/C/xclients.dt.
ACTION Open
 	LABEL				Open
 	ARG_TYPE			XWD
 	TYPE				MAP
 	MAP_ACTION		Xwud
The TYPE field specifies that this is a map action; the MAP_ACTION field specifies this action runs the Xwud action. The ARG_TYPE field specifies that this action applies only to files whose data type is XWD.
Compare the previous definition of the Open action to the next definition, which appears in the database file /usr/dt/appconfig/types/C/dt.dt.
ACTION Open
 	LABEL					Open
 	ARG_TYPE				BM
 	TYPE					MAP
 	MAP_ACTION			Dticon
This definition applies to files of data type (ARG_TYPE) BM (bitmap files). The definition maps the Open action to the Dticon action, which runs Icon Editor.
Defining the Double-Click Behavior of the Data Type
The data type's double-click behavior is defined by the first entry in the ACTIONS field. For example, for the XWD data type, the double-click behavior is to run the Open action, which in turn runs the Xwud action.
Dropping a Data File on an Action Icon
When the user drops a data file on an action icon, the system runs the action using that data file as the argument for the action (see How Actions Use Data Files as Arguments).
For example, when an XWD data file is dropped on the Xwd Display icon, the Xwud action is run using the data file argument. This runs the xwud X client with that data file.
Creating Desktop Printing for a Data Type
Desktop printing provides these ways to print a data file:
In addition to desktop printing, many applications provide a way to print from within the application.
Desktop printing uses actions named Print. Print, like Open, is an action name that is used for many different types of data. Therefore, Print actions use action mapping and the ARG_TYPE field to customize printing for each data type.
For example, here is the Print action for the XWD data type. The definition is located in /usr/dt/appconfig/types/language/xclients.dt:
ACTION Print
 	LABEL					Print
 	ARG_TYPE				XWD
 	TYPE					MAP
 	MAP_ACTION			NoPrint
This Print action, specific to XWD files, is mapped to a NoPrint action. NoPrint is a special action defined in /usr/dt/appconfig/types/language/dt.dt. The NoPrint action displays a dialog box telling the user that this data type cannot be printed.
Compare the XWD Print action with the following Print action for PCL files:
ACTION Print
 	LABEL				Print
 	ARG_TYPE			PCL
 	TYPE				MAP
 	MAP_ACTION		PrintRaw
The PrintRaw action, defined in the configuration file /usr/dt/appconfig/types/language/print.dt, contains the command line for printing the PCL files.
ACTION PrintRaw
 	TYPE						COMMAND
 	WINDOW_TYPE				NO_STDIO
 	EXEC_STRING				/usr/dt/bin/dtlp -w %(File)Arg_1%
