Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Provide Alternate Text to Display for Each Language
To display per-locale text on the login screen Language menu instead of the default display of the locale name, modify the Dtlogin*language*languageName resource name resource in Xresources:
Dtlogin*En_US*languageName: American
The text American will now be displayed rather than the locale name En_US.
Changing the Login Screen Behavior
To customize the login screen behavior, you can modify resources specified in the Xconfig file.
To modify Xconfig, copy Xconfig from /usr/dt/config to /etc/dt/config. After modifying /etc/dt/config/Xconfig, tell the login server to reread Xconfig by typing:
/usr/dt/bin/dtconfig -reset
This which issues the command kill -HUP login server process ID)
Resources specified in the Xconfig file include:
Dtlogin*authorizeXaccess file specification
Dtlogin*environment—X server environment
Dtlogin*language—default language
Dtlogin*languageList—language list for login screen Language menu
Dtlogin*resourcesXresources specification
Dtlogin*setupXsetup file specification
Dtlogin*startupXstartup file specification
Dtlogin*sessionXsession file specification
Dtlogin*failsafeClientXfailsafe script specification
Dtlogin*resetXreset script specification
Dtlogin*userPath—PATH for Xsession and Xfailsafe
Dtlogin*systemPath—PATH for Xsetup, Xstartup, and Xfailsafe
Dtlogin*systemShell—SHELL for Xsetup, Xstartup, and Xfailsafe
Dtlogin.timeZone—TZ for all scripts
