The desktop configuration files include:
Action and data type definition files
Icon image files
An application group directory and its contents
Optionally: help data files and a Front Panel configuration file
The registration package is gathered under a top-level directory called the application root, or app_root.
The major categories of configuration fields under the app_root/dt/appconfig directory are shown in Table 5–1.
Table 5–1 Configuration Fields Major Categories|
Subdirectory |
Contents |
types |
Action and data type definition files |
help |
Desktop help files |
icons |
Bitmap and pixmap image files used by the application's actions and data types |
appmanager |
The directory and contents that create the application group |
Each of the major categories has subdirectories for language-dependent files. Default-language files are placed in the C directory.
