(* = default, + = default with no project file)
Print out this help message
Write file containing main()
Only generate files that have changed
Merge generated _stubs.c files with previous version
Don't merge existing and new stubs file
Specify a project to generate code for
Use default project settings, ignore project file
Application shows (maps) all windows at startup
Application shows (maps) only initially-visible windows
Silent mode, no messages written
Verbose mode, detailed progress messages
