_JVM_ARGS Environment |
Java HotSpot VM Option |
Description |
bound_threads |
-Xboundthreads |
This option forces all threads to be created as bound threads (default in 1.4, not in 1.3). |
fixed_size_young_gen |
-Xmn<size> |
Disable young generation resizing. To do this on the Java HotSpot VM, simply set the size of the young generation to a constant (in 1.4; in 1.3, use -XX:MaxNewSize=<size> -XX:MaxNewSize=<size>). |
gc_stats |
-verbose:gc and/or -XX:+PrintGCDetails |
Turns on various forms of gc statistics gathering. |
ims_concurrent |
none |
inline_instrs |
-XX:MaxInlineSize=<size> |
Integer specifying maximum number of bytecode instructions in a method which gets inlined. |
inline_print |
-XX:+PrintInlining |
Print message about inlined methods (debug only) |
no_parallel_gc |
none |
sync_final |
none |
yield_interval |
-XX:DontYieldALotInterval=<ms> |
(debug only) Interval in milliseconds between yields |
monitor_order |
none |
