You can run the following kinds of applications with the Solaris X server:
Applications written with the following toolkits:
OpenWindows toolkits: OLIT and XView
Motif toolkit
Xt toolkit
Applications written for the X protocol
SPARC OpenWindows Version 3 X11 applications compiled under SunOS 4.0/4.1 and compatible releases
The OpenWindows Version 3 X11 applications must adhere to the system Binary Compatibility Package.
Applications written with the following interfaces are not supported:
TNT, NeWS, and XVPS
SunView, SunWindows, and Pixrect
The Solaris X server supports the following client applications available from the X Consortium. These clients are also included as part of the Solaris environment.
xterm terminal emulator
twm window manager
xdm display manager
bitmap bitmap editor
xfd font display utility
xauth access control program
xhost access control utility
xrdb resource control program
xset user preference setting program
xsetroot root window appearance setting utility
xmodmap keyboard control utility
xlsfonts server font listing utility
xfontsel font selection utility
xlswins window listing utility
xwininfo window information utility
xlsclients client applications information utility
xdpyinfo server information display utility
xprop window and font properties utility
The following are some applications and libraries, all of which are available from the X Consortium, that run on the server but are not distributed or supported by Sun:
Andrew, InterViews
The uwm and wm window managers
The CLX Common Lisp interface
contrib X Consortium clients
