y
n/a
n
Required
_
_
_
3-32:
If the user traverses to
a menu while the keyboard focus policy is implicit, the focus policy temporarily
changes to explicit and reverts to implicit whenever the user traverses out
of the menu system.
Menus must always be traversable, even when
the keyboard focus policy is generally implicit.
Required
_
_
_
3-33:
Your application uses the
F10 key to activate the menu bar system if it is inactive. The location cursor
is placed on the first traversable cascading button in the menu bar. If there
are no traversable cascading buttons, the key does nothing.
F10 provides a consistent means of traversing to the menu bar using the keyboard.
Required
_
_
_
3-34:
When the keyboard focus
is in an element with an inactive pop-up menu and the context of the element
allows the pop-up menu to be displayed, your application uses the menu key
to activate the pop-up menu. The location cursor is placed on the default
item of the menu, or on the first traversable item in the pop-up menu if there
is no default item.
The Menu key provides a uniform way of activating
a pop-up menu from the keyboard.
Required
_
_
_
3-35:
is in an option button, your application uses the Select key or the Spacebar
to post the option menu. The location cursor is placed on the previously selected
item in the option menu; or, if the option menu has been pulled down for the
first time, the location cursor is placed on the default item in the menu.
If there is an active option menu, the Return, Select, or Spacebar keys select
the current item in the option menu, unpost the menu system, and return the
location cursor to the option button.
These keys provide a means
of posting an option menu from the keyboard that is consistent across applications.
Required
_
_
_
3-36:
Down Arrow, Left Arrow, Right Arrow, and Up Arrow keys to traverse through
the items in a menu system.
The Down Arrow, Left Arrow, Right
Arrow, and Up Arrow directional keys provide a consistent means of navigating
among items in a menu system.
Required
_
_
_
3-37:
When a menu traversal action
traverses to the next or previous component in a menu or menu bar, the order
of traversal and the wrapping behavior are the same as that of the corresponding
component navigation action within a field.
This specification
provides consistency between menu traversal and component navigation within
a field.
Required
_
_
_
3-38:
If your application uses
any two-dimensional menus, they do not contain any cascading buttons.
Cascading buttons in a two-dimensional menu would restrict the user's ability
to navigate to all of the elements of the menu using the keyboard.
Required
_
_
_
3-39:
When focus is on a component
in a menu or menu bar system, the Down Arrow key behaves in the following
way:
If the component is in a vertical or two-dimensional menu,
traverse down to the next traversable component, wrapping within the menu
if necessary.
If the component is in a menu bar, and the component with
the keyboard focus is a cascading button, post its associated pull-down menu
and traverse to the default entry in the menu or, if the menu has no default,
to the first traversable entry in the menu.
This rule results in consistent operation of the directional
keys in a menu or menu bar system.
Required
_
_
_
3-40:
in a menu or menu bar system, the Up Arrow key behaves in the following way:
If the component is in a vertical or two-dimensional menu, this
action traverses up to the previous traversable component, wrapping within
the menu if necessary, and proceeding in the order opposite to that of the
Down Arrow key.
directional keys in a menu or menu bar system.
Required
_
_
_
3-41:
in a menu or menu bar system, the Left Arrow key behaves in the following
way:
If the component is in a menu bar or two-dimensional menu,
but not at the left edge, traverse left to the previous traversable component.
If the component is at the left edge of a menu bar, wrap within
the menu bar.
If the component is at the left edge of a vertical or two-dimensional
menu that is the child of a vertical or two-dimensional menu, unpost the current
menu and traverse to the parent cascading button.
menu that is the child of a menu bar, unpost the current menu and traverse
left to the previous traversable entry in the menu bar. If that entry is a
cascading button, post its associated pull-down menu and traverse to the default
entry in the menu or, if the menu has no default, to the first traversable
entry in the menu.
Required
_
_
_
3-42:
in a menu or menu bar system, the Right Arrow key behaves in the following
way:
If the component is a cascading button in a vertical menu,
post its associated pull-down menu and traverse to the default entry in the
menu or, if the menu has no default, to the first traversable entry in the
menu.
but not at the right edge, traverse right to the next traversable component.
If the component is at the right edge of a menu bar, wrap
within the menu bar.
If the component is not a cascading button and is at the right
edge of a vertical or two-dimensional menu, and if the current menu has an
ancestor cascading button (typically in a menu bar) from which the Down Arrow
key posts its associated pull-down menu, unpost the menu system pulled down
from the nearest such ancestor cascading button and traverse right from that
cascading button to the next traversable component. If that component is a
entry in the menu.
Required
_
_
_
3-43:
All menu traversal actions,
with the exception of menu posting, traverse to tear-off buttons in the same
way as for other menu entries.
Traversal of tear-off buttons
needs to be consistent with traversal of other menu items.
Required
_
_
_
3-44:
the F10, Menu, or Cancel key to unpost an entire menu system and an explicit
focus policy is in use, the location cursor is moved back to the component
that had it before the menu system was posted.
Returning the
location cursor to the component that had it previously allows the user to
resume a task without disruption.
