To register a pattern and send a notice that matches the pattern, type:
% tttrace -a myclientprogram
Example 4-1 shows the results.
tt_open() = 0x51708=="7.jOHHM X 129.144.153.55 0" (TT_OK) tt_fd() = 11 (TT_OK) tt_pattern_create() = 0x50318 (TT_OK) tt_pattern_category_set(0x50318, TT_OBSERVE) = 0 (TT_OK) tt_pattern_scope_add(0x50318, TT_SESSION) = 0 (TT_OK) tt_pattern_op_add(0x50318, 0x2f308=="Hello World") = 0 (TT_OK) tt_default_session() = 0x519e0=="X 129.144.153.55 0" (TT_OK) tt_pattern_session_add(0x50318, 0x519e0=="X 129.144.153.55 0") = 0 (TT_OK) tt_pattern_register(0x50318) = 0 (TT_OK) tt_message_create() = 0x51af0 (TT_OK) tt_message_class_set(0x51af0, TT_NOTICE) = 0 (TT_OK) tt_message_address_set(0x51af0, TT_PROCEDURE) = 0 (TT_OK) tt_message_scope_set(0x51af0, TT_SESSION) = 0 (TT_OK) tt_message_op_set(0x51af0, 0x2f308=="Hello World") = 0 (TT_OK) tt_message_send(0x51af0) ... TT_CREATED => TT_SENT: TT_SENT TT_PROCEDURE TT_NOTICE (TT_DISCARD in TT_SESSION): 0 == TT_OK id: 0 7.jOHHM X 129.144.153.55 0 op: Hello World session: X 129.144.153.55 0 sender: 7.jOHHM X 129.144.153.55 0 = 0 (TT_OK) tt_message_receive() ... Tt_message => procid <7.jOHHM X 129.144.153.55 0> TT_SENT TT_PROCEDURE TT_NOTICE (TT_DISCARD in TT_SESSION): 0 == TT_OK id: 0 7 jOHHM X 129.144.153.55 0 op: Hello World session: X 129.144.153.55 0 sender: 7.jOHHM X 129.144.153.55 0 pattern: 0:7.jOHHM X 129.144.153.55 0 = 0x51af0 (TT_OK)
To see ttsession's view of the message flow, type:
% tttrace -a
ttsession's view of mylientprogram's message flow is shown in Example 4-2.
tt_message_reply:
TT_SENT => TT_HANDLED:
TT_HANDLED TT_PROCEDURE TT_REQUEST (TT_DISCARD in TT_SESSION): 0 == TT_OK
id: 0 2.jOHHM X 129.144.153.55 0
op: Session_Trace
args: TT_IN string: "> /tmp/traceAAAa002oL; version 1; states"[...]
sender: 2.jOHHM X 129.144.153.55 0
pattern: 0:X 129.144.153.55 0
handler: 0.jOHHM X 129.144.153.55 0
Tt_message => procid <2.jOHHM X 129.144.153.55 0>
tt_message_send:
TT_CREATED TT_PROCEDURE TT_NOTICE (TT_DISCARD in TT_SESSION): 0 == TT_OK
op: Hello World
sender: 7.jOHHM X 129.144.153.55 0 TT_CREATED => TT_SENT:
op: Hello World
sender: 7.j HHM X 129.144.153.55 0
Tt_message & Tt_pattern {
id: 0:7.jOHHM X 129.144.153.55 0
category: TT_OBSERVE
scopes: TT_SESSION
sessions: X 129.144.153.55 0
ops: Hello World
} == 3;
The first message traced will almost always be ttsession's reply to the request sent to it by ttrace.
