The Simplified Chinese Solaris operating environment uses EUC code sets. Its printing applications (such as desktop tools) generate PostScript code that uses EUC. If you use different PostScript printing, make sure it has the same capabilities.
To print an EUC file, use the command in the following example:
system% lp EUC_filename |
To print a GB format file on a printer that supports this format, use the following command:
system% lp -T GB GB_filename |
For more information on setting up the GB filter, see Simplified Chinese Solaris System Administrator's Guide.
