The xetops and xutops utilities produce bitmapped graphics as printed images. Simplified Chinese Solaris software includes the xetops and xutops utilities so any system can print Simplified Chinese text on a PostScript printer. The xetops utility in EUC locale and xutops Utility in UTF--8 locale may no longer be supported in the future.
xetops handles files in the EUC locale, such as zh
xutops handles files in the UTF-8 locale, such as zh.UTF-8.
A typical command line for printing a file named filename containing Simplified Chinese characters with xetops, would be as follows:
system% pr filename | xetops | lp |
system% xetops -h |
The following syntax information is returned:
xetops [-r] [-B|[-T [-t S|F|K|H] [-s [i]|m|c]
[-p A3|A4|A5|B5|USLtr|USLgl]
[-o length=i|c| [,width=i|c]]
[filename]
The options for xetops are as following:
-r: prints the file in landscape mode.
-B: prints the file using bitmap fonts. (The default is TrueType SongTi font.)
-t: use this option to specify up to four typefaces. S indicates SongTi, F indicates FangSongTi, K indicates KaiTi, and H indicates HeiTi.
-s: designates the size of each character. i stands for inches, m stands for millimeters, and c stands for centimeters. (The default is inches.)
-p: specifies the paper size (A3, A4, A5, B5, US Letter, or US Legal).
-o: specifies the length and width of the paper. i stands for inches, and c stands for centimeters. (The default is the number of the lines.)
Here are some examples of pr and xetops. The following command:
will print the file using the SongTi TrueType font. The printed characters will be 4mm in size.
system% pr filename | xetops -t K -s 8m | lp |
will print the file using the KaiTi TrueType font. The printed characters will be 8mm in size.
system% xetops -t H -s 1.2 filename | lp |
will print the file using the HeiTi TrueType font. The printed characters will be 1.2 inches in size.
system% xetops -B filename | lp |
will print the file using a bitmap font.
The syntax for xutops is similar:
system% pr filename | xutops | lp |
Make filename the name of the file to print. This file can contain ASCII/English characters as well as Simplified Chinese.
