Simplified Chinese Solaris User's Guide
Converting the Source Codetable File from Text Format to Binary Format or from Binary Format to Text Format:
Use the utility tools txt2bin to convert a text codetable file to binary file. and bin2txtto convert binary format file to text format file.
bin2txt and txt2bin are under directory: /usr/lib/im/locale/zh_CN/common.
The command syntax is:
 # /usr/lib/im/locale/zh_CN/common/txt2bin
source_codetable_file
binary_codetable_file
  # /usr/lib/im/locale/zh_CN/common/bin2txt
