This section contains instructions on how to use the array input method to input Chinese characters.
Type Control-spacebar to turn on Chinese input conversion.
The mode appears in the status area.
Type x.
The Array input converter finds several matching characters, so it automatically displays a lookup choice window:
Type [Shift + a] to select the appropriate character.
The radicals are converted and the corresponding character appears:
