This section contains instructions on how to use the Boshiamy input method to input Chinese characters.
Type Control-spacebar to turn on Chinese input mode.
The mode appears in the status area.
Type the sets of radicals: uoo. Press the spacebar to convert it to the corresponding character.
The input converter finds five matching characters and displays a lookup choice window:
Type a number key to select the appropriate character, such as 1 to select the first candidate:
