Type Control-spacebar to turn on TsangChieh mode.
The mode appears in the status area.
Type the set of radicals; o Press the spacebar after each set to convert it to a character.
The DaYi input converter finds six matching characters and displays a lookup choices as below:
Type a number key to select the appropriate character, such as 1 to select the first candidate:
