To type Chinese characters in this mode, type the Chinese radicals that make up the Chinese characters. If you do not have a Taiwan Chinese keyboard that shows the radicals on the keys, refer to a picture of the Chinese keyboard to see how the Chinese radicals map to your keyboard.
Type Control-spacebar to turn on TsangChieh mode.
The mode appears in the status area.
Type ir.
The TsangChieh input converter finds two matching characters and displays a lookup choice window:
Press 2 to select the appropriate character.
The radicals are converted and the correct character appears:
