Serial Ports is available from the Admintool menu to configure serial ports for terminals. Serial Ports provides the easiest method of installing a terminal. Serial Ports is invoked by admintool. For more information on admintool, see System Administration Guide.
Become superuser.
system% su |
Type admintool.
The admintool menu will appear.
system# admintool |
Select the Serial Ports icon.
A Chinese terminal is installed as you would install an ASCII terminal.
