Setting a User's TTY
To verify that your
TTY is properly set up:
Type the /bin/stty command with the -a
option:
If the values from above (cs8, -istrip)
are not listed, then use the following command to set them:
system% /bin/stty cs8 -istrip defeucw
This is the last step in setting up a terminal.
