To explicitly configure the STREAMS module for a Big5 terminal use:
setterm -x big5 |
This usage is independent of terminfo.
Further consider using a VT-100 terminal (which is Big5 compatible) on a system with an entry like the following (which is appropriate for such a terminal) in the terminfo database:
vt100-b|VT-100-compatible with Big-5 chars, lines#40, .csin=E(BE)IE[?1h, csin=E(BE)I, devt=PACKBig5, s0ds=E(H, s1ds=E$@, s2ds=E(H, use=cit600, |
A configuring command that references this entry would be:
setterm -t vt100-b |
For setterm to work properly in this application, /usr/share/lib/setterm/zh_TW/conf.file must contain an entry that corresponds to the device type. This entry gives setterm instructions for placing appropriate conversion modules in the TTY stream; for example:
big5throw \
popto zs|mcp|mti|ptem \
push big5euc \
push ldterm \
push ttcompat \
run {stty defeucw} \
catch
GenericEUC|EUCthrow \
push ldterm \
push ttcompat \
catch
ASCIIthrow \
push ldterm \
push ttcompat \
catch
For more information, refer to the setterm(1)man page. Once configured, conversion is enabled by default. Applications can also set features through ioctl() function calls.
