In reference to the Korean window system input server, the keybinding process links certain keys on the keyboard with certain actions by an application. You can keybind a complex action by an application, such as closing an application's open windows, to a single key or sequence of keys like Control-H or Esc w c.
All input conversion mode Control-key commands associated with non-ASCII input conversion are set in /usr/lib/mle/ko/keybind.dat and /usr/lib/mle/ko.UTF-8/keybind.dat, depending upon the locale setting. The default commands are listed in the table at the end of Chapter 4, "Entering Korean Input," in Korean Solaris User's Guide.
