Keybindings can be changed by changing the names of the keys in keybind.dat and restarting the htt input server. You can create and use your own customized keybind.dat file as follows:
Create a customized copy named keybind.dat in another directory.
Set the environment variable MLE_PATH to the path name of the directory containing this customized file.
Start the input server.
The directory set in MLE_PATH is searched for an instance of the keybind.dat file and the commands in that file are set for the user.
If MLE_PATH is not set or does not contain a usable keybind.dat file, /usr/lib/mle/ko/keybind.dat or /usr/lib/mle/ko.UTF-8/keybind.dat is used, according to the locale.
To change the keybindings, edit the keybinding file to replace default keys with new keys. Key combinations and ON/OFF toggling can also be used.
