To explicitly configure the STREAMS module for EUC (Completion code) terminal type:
system% setterm -x EUC |
For some more examples, consider using a Packed (Combination) code terminal, which uses either the Packed or Johap module.
To explicitly initialize the Packed STREAMS module, which supports a Combination code of KS C 5601-1987:
system% setterm -x PACK |
To explicitly initialize the Johap STREAMS module, which supports a Combination code of KS C 5601-1992:
system% setterm -x JOHAP |
This usage is independent of terminfo.
Further consider using a FAST-15 Packed code terminal on a system with an entry like the following (which is appropriate for such a terminal) in the terminfo database:
fast-15 | fast-pack | korean terminal packed mode, devt=PACK, use=vt100-w, |
A configuring command that references this entry would be:
system% setterm -t fast-15 |
For setterm to work properly in this application, /usr/share/lib/setterm/ko/conf.file must contain an entry that corresponds to the device type. This entry gives setterm instructions for placing appropriate conversion modules in the TTY stream; for example:
KoreanPACK|PACKthrow \
popto zs|mcp|mti|ptem \
push kpack \
push ldterm \
push ttcompat \
run {stty defeucw} \
catch
KoreanJOHAP|JOHAP throw \
push kjohap \
push ldterm \
push ttcompat \
catch
GenericEUC|EUCthrow \
push ldterm \
push ttcompat \
catch
ASCIIthrow \
push ldterm \
push ttcompat \
catch
For more information, refer to the setterm(1) man page.
