To explicitly configure the STREAMS module for the ko.UTF-8 locale:
system% setterm -x u8 |
To explicitly initialize the STREAMS module for an EUC terminal to use the ko.UTF-8 locale:
system% setterm -x ku8euc |
To explicitly initialize the Johap STREAMS module, which supports a Combination code of KS C 5601-1992 terminal, to use the ko.UTF-8 locale:
system% setterm -x ku8johap system% stty defeucw cs8 -istrip |
For setterm to work properly in this application, /usr/share/lib/setterm/ko.UTF-8/conf.file must contain an entry that corresponds to the device type. This entry gives setterm instructions for placing appropriate conversion modules in the TTY stream; for example
# Korean specific entries:
# Completion/Wansung/EUC code terminal support (KS C 5601-1992)
KoreanU8EUC|KU8EUCthrow \
popto zs|mcp|mti|ptem \
push ku8euc \
push eucu8 \
push ldterm \
push ttcompat \
push u8euc \
run {stty defeucw} \
catch
# Combination code terminal support (KS C 5601-1992 Annex 3)
KoreanU8JOHAP|KU8JOHAPthrow \
push ku8johap \
push eucu8 \
push ldterm \
push ttcompat \
push u8euc \
catch
For more information, refer to the setterm(1) man page.
