To verify that your TTY is properly set up:
Type the /bin/stty command with the -a option:
system% /bin/stty -a |
If the values from above (cs8, -istrip) are not listed, then use the following command to set them:
system% /bin/stty cs8 -istrip defeucw |
This is the last step in setting up a terminal. The default setting of a Korean terminal is the Completion-code mode. For installing a Packed-code TTY, continue to the next section.
