Using Packed Code and Johap TTY in the ko Locale
If you are using a Packed code type terminal, you must load the STREAMS
module into the kernel.
If you are using a Packed code terminal (KS C 5601-1987), you should
load kpack by typing the following command as superuser:
system% su
Password: (Type superuser password here if required.)
# modload /kernel/strmod/kpack
Type the following command:
