Korean Solaris System Administrator's Guide
Using Combination Code and Johap TTY in the ko Locale
  1. If you are using a Combination code terminal (KS C 5601-1992), load kjohap by typing the following command as superuser:
    system% su
    Password: (Type superuser password here if required.)
    # modload /usr/kernel/strmod/kjohap
  2. Type the following command:
    system% setterm -x JOHAP
