Korean Solaris System Administrator's Guide
Using EUC TTY in the ko.UTF-8 Locale
  1. If you are using an EUC terminal (KS C 5601-1987-0), load the ku8euc module by typing the following command as superuser:
    system% su
    Password: (Type superuser password here if required.)
    # modload /kernel/strmod/ku8euc
  2. To enable the stream module:
    system% setterm -x KU8EUC
  3. To enable 8-bit I/O:
    system% stty defeucw cs8 -istrip
  4. If you want to use dtterm, type the following command:
    system% setterm -x u8
