If you are using a Johap code terminal (KS C 5601-1992-3), load the ku8johap module by typing the following command as superuser:
system% su Password: (Type superuser password here if required.) # modload /kernel/strmod/ku8johap |
To enable the stream module:
system% setterm -x KU8JOHAP |
To enable 8-bit I/O:
system% stty defeucw cs8 -istrip |
If you want to use dtterm, type the following command:
system% setterm -x u8 |
