The Desktop Management Interface(DMI) Protocol command line interface consists of two utilities that retrieve DMI Service Provider (SP) information:
The dmi_cmd utility provides the ability to:
Obtain version information about the DMI SP
Set the configuration to describe the language required by the management application
Obtain the configuration information describing the current language in use for the session
Install components into the database
List components in a system to determine what is installed
Delete an existing component from the database
Install group schemas to an existing component in the database
List class names for all groups in a component
List the groups within a component
Delete a group from a component
Install a language schema for an existing component in the database
List the set of language mappings installed for a specified component
Delete a specific language mapping for a component
List properties for one or more attributes in a group
The dmiget utility retrieves the table information of a specific component in the DMI SP.
dmi_cmd [-s hostname] -h | -V | -W config | -X | -CI mif_filename | -CL [-c compId] [-r reqMode] [-d] [-p] [-m maxCount] | -CD -c compId | -GI schema_filename -c compId | -GL -c compId -g groupId [-r reqMode] [-d] [-p] [-m maxCount] | -GM -c compId [-m maxCount] | -GD -c compId -g groupId | -NI schema_filename -c compId | -NL -c compId | -ND -c compId -l language_string | -AL -c compId -g groupId [-a attrId] [-r reqMode] [-d] [-p] [-m maxCount]
The command line arguments for dmi_cmd are shown in Table 7–1.
Table 7–1 dmi_cmd Command Line Arguments|
Argument |
Description |
-s hostname |
Specifies the host machine that dmisp is running on; the default host is the local host |
-h |
Prints usage information |
-V |
Retrieves version information about the DMI SP |
-W config |
Sets the configuration specified in config to dmisp |
-X |
Retrieves configuration information describing the current language in use |
-CI mif_filename |
Installs the component specified in mif_filename |
Lists components |
-CD -c compId |
Deletes the component specified by compId |
Installs the group schema specified in schema_filename |
Lists the groups for a specified component |
Lists class names for a specified component |
Deletes specified groups for a specified component |
Installs the language schema specified in schema_filename |
-NL -c compId |
Lists language mappings for a specified component |
Deletes language mapping for a specified component |
-AL -c compId -g groupId [-a attrId] [-r reqMode] [-d] [-p] [-m maxCount] |
Lists attributes for a specified component |
The values for compId, groupId, attrId, and maxCount are positive integers. The default value is 0.
The valid integer values for reqMode are:
1 (DMI_UNIQUE)
2 (DMI_FIRST)
3 (DMI_NEXT)
The default value for reqMode is 1 (DMI_UNIQUE). If an invalid reqMode is specified, the default value is used.
When listing components (-CL), groups (-GL), or attributes (-AL), use the -d option to display descriptions and the -p option to display the pragma string.
The following command lists the component ID, name, and description of up to 5 components, starting from component 3 in the dmispd running on the host snowbell, by using the default request mode (DMI_UNIQUE).
%dmi_cmd -s snowbell -CL -d -c 3 -m 5 Connecting to dmispd on the snowbell... CompId: 4 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 5 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 6 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 7 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 8 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code.
The following command lists the ID, name, storage, access mode, date type, and maximum size of all attributes in group 1 of component 1 in the dmispd running on local host, by using default request mode (DMI_UNIQUE). No description is displayed, and no limitation is set for max count.
%dmi_cmd -AL -g 1 -c 1 Connecting to dmispd on the localhost... 12 attrs listed for group 1 of comp 1 Attr Id: 1 Name: Manufacturer Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 2 Name: Product Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 3 Name: Version Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 4 Name: Serial Number Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 5 Name: Installation Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DATE maxSize: 0 Attr Id: 6 Name: Verify Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 7 Name: ComponentId Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 8 Name: ComponentName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 9 Name: ComponentDesc Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 10 Name: GroupId Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 11 Name: GroupName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 12 Name: LanguageName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256
The following command installs namedir.mif in dmispd running on localhost. The file namedir.mif is located in the directory specified in the configuration file.
%dmi_cmd -CI namedir.mif Connecting to dmispd on the localhost... "namedir.mif" is installed as comp 21.
The following command uninstalls component 5 in dmispd running on localhost.
%dmi_cmd -CD -c 5 Connecting to dmispd on the localhost... comp 5 is uninstalled.
The following command displays the version of dmispd running on the snowbell machine.
%dmi_cmd -s snowbell -V Connecting to dmispd on the snowbell... dmispd version: Dmi2.0 description: This is a DMI2.0 based on ONC RPC
dmiget [-s hostname]
-h |
{-c compId [-g groupId] [-a attrId]}
The command line arguments for dmiget are described in Table 7–2.
Table 7–2 dmiget Command Line Arguments|
Argument |
Description |
-s hostname |
-h |
-c compId |
Displays all the table information for a specified component |
-g groupId |
Displays the group information for a component specified with the -c argument |
-a attrId |
Displays the attributes for the component specified with the -c argument |
The following command displays the table information in group 2 of component 3.
%dmiget -c 3 -g 2 Connecting to dmispd on the localhost... For group 2 of component 3: Id: 10, 10 Id: 20, developer1 Id: 30, SunSoft Id: 40, Solaris 2.6 Id: 10, 20 Id: 20, developer2 Id: 30, SunSoft Id: 40, Solaris 2.6 Id: 10, 30 Id: 20, developer3 Id: 30, SunSoft Id: 40, Solaris 2.6
The following command displays the table information for component 3.
%dmiget -c 3 Connecting to dmispd on the localhost... For group 1 of component 3: Id: 1, SunSoft Id: 2, DMTF Demonstration Id: 3, Version 1.0 Id: 4, 1.00000 Id: 5, 1994 06 03 09 00 00 Id: 6, 0 Id: 7, 0 Id: 8, Id: 9, Id: 10, 0 Id: 11, Id: 12, For group 2 of component 3: Id: 10, 10 Id: 20, developer1 Id: 30, SunSoft Id: 40, Solaris 2.6 Id: 10, 20 Id: 20, developer2 Id: 30, SunSoft Id: 40, Solaris 2.6 Id: 10, 30 Id: 20, developer3 Id: 30, SunSoft Id: 40, Solaris 2.6 For group 42 of component 3: Id: 1, Circus Id: 2, 4.0a Id: 1, Disk Blaster Id: 2, 2.0c Id: 1, Oleo Id: 2, 3.0 Id: 1, Presenter Id: 2, 1.2
The following command displays table information for attribute 20 in group 2 of component 3.
%dmiget -c 3 -g 2 -a 20 -s snowbell Connecting to dmispd on the snowbell... For group 2 of component 3: Id: 20, developer1 Id: 20, developer2 Id: 20, developer3
