Some of the error messages for Solstice Enterprise Agents (SEA) are listed in this section. They are worded to be fairly intuitive and easy to understand. Also, to make them easier to find, the messages are presented here in alphabetical order. Their number follows, to the right of the listing.
To see the messages listed by number, see Section A.2 "Messages by Number".
ADD Messages |
ADD_XLATE_outOfMemory |
738 |
AR CONNECT Messages |
AR_CONNECT_AND_OPEN_connectFailed |
102 |
AR_CONNECT_AND_OPEN_getHostNameFailed |
101 |
AR_CONNECT_AND_OPEN_openFailed |
103 |
All error messages are logged into the /var/adm/messages Syslog facility.
AR and DMI REGISTER Messages |
AR_REGISTER_noneRegistered |
112 |
AR_REGISTER_someRegistered |
111 |
DMI_REGISTER_badCmdHandle |
833 |
DMI_REGISTER_badLevelCheck |
832 |
DMI_REGISTER_failed |
831 |
DMI_REGISTER_outOfMemory |
838 |
BUILD Messages |
BUILD_OID_LIST_outOfMemory |
748 |
BUILD_SET_ATTRIBUTE_failed |
960 |
BUILD_SET_ATTRIBUTE_outOfMemory |
968 |
CLOSE Messages |
AR_CLOSE_failed |
CREATE Messages |
CREAT_BUFFER_invalidOid |
711 |
CREAT_BUFFER_outOfMemory |
718 |
CREATE_COMP_LIST_dmiBroke |
756 |
CREATE_COMP_LIST_outOfMemory |
758 |
CREATE_GC_PAIRS_dmiBroke |
766 |
CREATE_GC_PAIRS_outOfMemory |
768 |
DO Messages |
DO_DMI_SETUP_createSemFailed |
801 |
DO_DMI_SETUP_createQueueFailed |
802 |
EXTRACT Messages |
EXTRACT_OID_invalidOid |
721 |
EXTRACT_OID_outOfMemory |
728 |
FIND Messages |
FIND_ATTRIBUTE_ACCESS_notFound |
981 |
FIND_ATTRIBUTE_ACCESS_otherError |
982 |
FIND_ATTRIBUTE_ACCESS_dmiBroke |
986 |
FIND_ATTRIBUTE_TYPE_notFound |
991 |
FIND_ATTRIBUTE_TYPE_otherError |
992 |
FIND_ATTRIBUTE_TYPE_dmiBroke |
992 |
GET Messages |
GET_ATTRIBUTE_arBroke |
247 |
GET_ATTRIBUTE_cnfBufAddressability |
241 |
GET_ATTRIBUTE_dmiBroke |
246 |
GET_ATTRIBUTE_genErr |
245 |
GET_ATTRIBUTE_tooBig |
254 |
GET_COMP_MIB_arBroke |
257 |
GET_COMP_MIB_dmiBroke |
256 |
GET_COMP_MIB_genErr |
255 |
GET_COMP_MIB_noSuchInstance |
251 |
GET_COMP_MIB_noSuchInstanceOrObject |
252 |
GET_COMP_MIB_noSuchObject |
253 |
GET_COMP_MIB_tooBig |
254 |
GET_DMI_KEY_SIZE_badAttributeType |
431 |
GET_FIND_GC_PAIR_pairNotFound_groupMatch |
221 |
GET_FIND_GC_PAIR_pairNotFound_noGroupMatch |
222 |
GET_GC_PAIRS_dmiBroke |
776 |
GET_GC_PAIRS_outOfMemory |
778 |
GET_INTERNAL_KEY_SIZE_otherError |
441 |
GET_NEXT_COMP_MIB_genErr |
405 |
GET_NEXT_COMP_MIB_outOfMemory |
408 |
GET_NEXT_COMP_MIB_tooBig |
401 |
GET_KEY_VALUE_noneHigher |
411 |
GET_KEY_VALUE_otherError |
412 |
GET_KEY_VALUE_outOfMemory |
418 |
GET_PARSE_INSTANCE_notFullySpecified |
211 |
GET_PARSE_INSTANCE_programmingError |
219 |
GN Messages |
GN_FIND_COMPONENT_notFound |
363 |
GN_FIND_GROUP_foundNoChange |
341 |
GN_FIND_GROUP_notFound |
342 |
GN_FIND_KEY_noKeyExists |
371 |
GN_FIND_KEY_notFound |
372 |
GN_GET_OBJECT_dmiBroke |
386 |
GN_GET_OBJECT_genErr |
385 |
GN_GET_OBJECT_outOfMemory |
388 |
GN_GET_OBJECT_tooBig |
381 |
GN_PARSE_INSTANCE_badOid |
321 |
INIT Messages |
INIT_SUB_AGENT_createSemFailed |
91 |
INIT_SUB_AGENT_outOfMemory |
98 |
INIT_SUB_AGENT_rpcregfailed |
90 |
ISSUE Messages |
ISSUE_LIST_COMP_badCmdHandle |
902 |
ISSUE_LIST_COMP_badLevelCheck |
901 |
ISSUE_LIST_COMP_failed |
900 |
ISSUE_LIST_COMP_outOfMemory |
908 |
ISSUE_LIST_GROUP_badCmdHandle |
912 |
ISSUE_LIST_GROUP_badLevelCheck |
911 |
ISSUE_LIST_GROUP_failed |
910 |
ISSUE_LIST_GROUP_outOfMemory |
918 |
ISSUE_LIST_ATTRIBUTE_badCmdHandle |
922 |
ISSUE_LIST_ATTRIBUTE_badLevelCheck |
921 |
ISSUE_LIST_ATTRIBUTE_failed |
920 |
ISSUE_LIST_ATTRIBUTE_outOfMemory |
928 |
ISSUE_LIST_DESCRIPTION_badCmdHandle |
932 |
ISSUE_LIST_DESCRIPTION_badLevelCheck |
931 |
ISSUE_LIST_DESCRIPTION_failed |
930 |
ISSUE_LIST_DESCRIPTION_outOfMemory |
938 |
ISSUE_GET_ATTRIBUTE_badCmdHandle |
942 |
ISSUE_GET_ATTRIBUTE_badLevelCheck |
941 |
ISSUE_GET_ATTRIBUTE_failed |
940 |
ISSUE_GET_ATTRIBUTE_outOfMemory |
948 |
ISSUE_GET_ROW_badCmdHandle |
952 |
ISSUE_GET_ROW_badLevelCheck |
951 |
ISSUE_GET_ROW_failed |
950 |
ISSUE_GET_ROW_outOfMemory |
958 |
ISSUE_SET_ATTRIBUTE_badCmdHandle |
972 |
ISSUE_SET_ATTRIBUTE_badLevelCheck |
971 |
ISSUE_SET_ATTRIBUTE_failed |
970 |
ISSUE_SET_ATTRIBUTE_outOfMemory |
KEY Messages |
KEY_FROM_AR_illegalKey |
873 |
KEY_FROM_AR_otherError |
874 |
KEY_FROM_AR_outOfMemory |
878 |
KEY_FROM_AR_tooLong |
872 |
KEY_FROM_AR_tooShort |
871 |
KEY_TO_AR_otherError |
881 |
KEY_TO_AR_outOfMemory |
888 |
PREPARE Messages |
PREPARE_FOR_DMI_INVOKE_resetSemFailed |
821 |
SET Messages |
SET_ADD_TO_RESERVE_LIST_outOfMemory |
618 |
SET_ATTRIBUTE_badPacketType |
552 |
SET_ATTRIBUTE_dmiBroke |
556 |
SET_ATTRIBUTE_genErr |
555 |
SET_ATTRIBUTE_otherError |
551 |
SET_CHECK_ILLEGAL_dmiBroke |
576 |
SET_CHECK_ILLEGAL_genErr |
575 |
SET_CHECK_ILLEGAL_gotError |
571 |
SET_COMP_MIB_badPacketType |
602 |
SET_COMP_MIB_commitFailed |
581 |
SET_COMP_MIB_dmiBroke |
606 |
SET_COMP_MIB_genErr |
605 |
SET_COMP_MIB_noAccess |
583 |
SET_COMP_MIB_noCreation |
584 |
SET_COMP_MIB_notWritable |
591 |
SET_COMP_MIB_resourceUnavailable |
601 |
SET_COMP_MIB_wrongLength |
593 |
SET_COMP_MIB_wrongType |
592 |
SET_COMP_MIB_wrongValue |
594 |
TRACE Messages |
TRACE_KEY_outOfMemory |
1008 |
TRANSLATE Messages |
TRANSLATE_DMI_KEY_TO_INTERNAL_otherError |
421 |
TRANSLATE_DMI_KEY_TO_INTERNAL_outOfMemory |
428 |
DMI UNREGISTER and UNREGISTER Messages |
DMI_UNREGISTER_failed |
841 |
DMI_UNREGISTER_outOfMemory |
848 |
UNREG_BY_AR_failed |
171 |
XLATE Messages |
XLATE_TYPE_mifUnknownType |
893 |
XLATE_TYPE_noError_opaqueType |
891 |
XLATE_TYPE_otherError |
894 |
XLATE_TYPE_unexpectedType |
892 |
90 |
91 |
98 |
101 |
102 |
103 |
111 |
112 |
171 |
211 |
219 |
221 |
222 |
241 |
244 |
245 |
246 |
247 |
251 |
252 |
253 |
254 |
255 |
256 |
257 |
321 |
341 |
342 |
363 |
371 |
372 |
385 |
386 |
388 |
401 |
405 |
408 |
411 |
412 |
418 |
421 |
428 |
431 |
441 |
552 |
555 |
556 |
571 |
575 |
576 |
581 |
583 |
584 |
591 |
592 |
593 |
594 |
601 |
602 |
605 |
606 |
618 |
711 |
718 |
721 |
728 |
738 |
756 |
758 |
766 |
768 |
776 |
778 |
821 |
833 |
841 |
848 |
871 |
872 |
873 |
874 |
878 |
891 |
892 |
893 |
894 |
900 |
901 |
902 |
908 |
910 |
911 |
912 |
918 |
920 |
921 |
922 |
928 |
930 |
931 |
932 |
938 |
940 |
941 |
942 |
948 |
950 |
951 |
952 |
958 |
960 |
968 |
970 |
971 |
972 |
978 |
981 |
982 |
986 |
991 |
992 |
996 |
1008 |
