Table 2–3 provides a list of default software locations for the DMI portion of the product.
Table 2–3 Default Locations for DMI|
Label |
Location |
SEA_DMILibrary_Directory |
/usr/lib |
SEA_DMIConfiguration_Directory |
/etc/dmi/conf |
SEA_DMIRunTime_Database_Directory |
/var/dmi/db |
SEA_DMIRunTime_MAP_Directory |
/var/dmi/map |
SEA_DMIMif_Directory |
/var/dmi/mif |
Table 2–4 provides a list of DMI component names and their default locations.
Table 2–4 DMI Package Components|
Component name |
Label/Directory |
Description |
snmpXdmid |
/usr/lib/dmi |
Mapper executable |
dmispd |
/usr/lib/dmi |
DMI Service Provider executable |
dmi_cmd |
/usr/sbin |
DMI command utility |
dmiget |
/usr/sbin |
snmpXdmid.conf |
Mapper configuration file |
dmispd.conf |
DMI SP configuration file |
map files |
Map files |
libdmi.so.1 |
SSA SDK DMI generic library |
libci.so.1 |
SSA SDK CI library |
libdmimi.so.1 |
SSA SDK MI library |
sp.mif |
MIF files |
ciinvoke |
/etc/dmi/ciagent |
DMI component interface invocation script |
