Table 2–1 shows a list of default software locations within SNMP.
Table 2–1 Default SNMP Locations|
Label |
Directory |
SEA_SNMPLibrary_Directory |
/usr/lib |
SEA_SNMPConfiguration_Directory |
/etc/snmp/conf |
SEA_SNMPMibs_Directory |
/var/snmp/mib |
Table 2–2 provides the list of SNMP component names and their default locations.
Table 2–2 SNMP Package Components|
Component Name |
Label/Directory |
Description |
snmpdx |
/usr/lib/snmp |
Master Agent executable |
mibiisa |
/usr/lib/snmp |
MIB II snmp daemonpwd |
snmp_trapsend |
/usr/sbin |
Utility for sending traps |
mibcodegen |
/usr/bin |
Code generator executable |
snmpdx.rsrc |
Master Agent resource file |
snmpdx.reg |
Registration file for agents |
snmpdx.acl |
Master Agent access control file |
snmpd.conf |
SNMPD configuration file |
mibiisa.reg |
MIB II subagent registration file |
mibiisa.rsrc |
MIB II agent resource file |
snmpdx.st |
SEA_SNMPRun_Time_Directory |
Master Agent status file |
libssasnmp.so.1 |
SSA SDK SNMP library |
libssagent.so.1 |
SSA SDK Agent library |
enterprises.oid |
Default enterprise-name OID map |
sun.mib |
Sun MIB |
snmpdx.mib |
Snmpdx MIB |
