In versions 1.1 and compatible of the ToolTalk service, ttsession will not read its types from the Classing Engine (CE) database; and the ToolTalk types compiler tt_type_comp will not merge types into the CE database.
This appendix describes how to migrate your existing ToolTalk-aware application from the CE database to the ToolTalk Types database.
The ToolTalk service provides a script called ttce2xdr to convert ToolTalk types stored in the CE database (which was the default database used by versions 1.0.x of the ToolTalk service) to the XDR-format database, which is the database used by versions 1.1 and compatible of the ToolTalk service.
The first time a ToolTalk 1.1 and compatible versions, ttsession is started, the user type database is automatically converted from the CE database to the new ToolTalk Types database. However, you can manually convert the current user database with the command:
ttce2xdr [ -xnh ] -d user |
Table A–1 describes the options for the ttce2xdr script.
Table A–1 ttce2xdr Script Options|
Option |
Description |
-x |
Displays the underlying commands executed by ttce2xdr. |
-n |
Displays the underlying commands that ttce2xdr can execute. |
-h |
Describes the options for ttce2xdr. |
-d |
Specifies the database to be converted: user, system, or network. |
The types are read from the CE database
~/.cetables/cetables
and written to the new ToolTalk Types database
~/.tt/types.xdr
A system CE database is the per-machine database. You will need to run the ttce2xdr script on each machine on which you have ToolTalk types. To determine whether there are any ToolTalk types in the system CE database, enter the following command on the command line:
tt_type_comp -Epd system |
No output is generated if there are no ToolTalk types in the system CE database.
You must be logged in as root to run the ttce2xdr script for the system CE databases.
To run the ttce2xdr script for the system CE database, enter the following commands on the command line:
ttce2xdr [ -xnh ] -d system |
Table A–2 describes the options for the ttce2xdr script.
Table A–2 ttce2xdr Script Options|
Option |
Description |
-x |
-n |
-h |
-d |
/etc/cetables/cetables
/etc/tt/types.xdr
A network CE database is the per-OW-installation database. You need to convert each network CE database that has ToolTalk types other than those shipped with the OpenWindows Version 3 product.
You must be logged in as root to run the ttce2xdr script for the network CE databases.
To convert a network-wide database, enter the following command on the command line:
ttce2xdr [ -xnh ] -d network [ OPENWINHOME-from [ OPENWINHOME-to ]] |
Table A–3 describes the options for the ttce2xdr script.
Table A–3 ttce2xdr Script Options|
Option |
Description |
-x |
-n |
-h |
-d |
Reads the types from the databases under this
directory. If |
Writes the types to the databases under this
directory. If |
$OPENWINHOME/lib/cetables/cetables
$OPENWINHOME/etc/tt/types.xdr
To move ToolTalk types other than the ones shipped with the OpenWindows Version 3 product from the network CE database to the network XDR database, enter the following command on the command line:
ttce2xdr -d network old_OPENWINHOME new_OPENWINHOME |
where old_OPENWINHOME is the OpenWindow installation that holds the old network CE database and new_OPENWINHOME is the OpenWindow installation in which to update the ToolTalk XDR database.
