The ToolTalk service returns error status in the function's return value rather than in a global variable. ToolTalk functions return one of these error values:
Tt_status
int
char* or opaque handle
Each return type is handled differently to determine if an error occurred. For example, the return value for tt_default_session_set is a Tt_status code. If the ToolTalk service sets the default session to the specified sessid:
Without a problem — the Tt_status
code returned is TT_OK.
With a problem — the Tt_status
code returned is TT_ERR_SESSION.
This status code informs you that the sessid you passed was not valid.
You can use the ToolTalk error handling functions shown in Table 14–1 to retrieve error values.
Table 14–1 Retrieving ToolTalk Error Status|
ToolTalk Function |
Description |
tt_pointer_error(char * return_val) |
Returns an error encoded in a pointer. |
tt_pointer_error((void *) (p)) |
Returns an error encoded in a pointer cast to VOID * . |
tt_int_error(int return_val) |
Returns an error encoded in an integer. |
The return type for these function is Tt_status.
You can use the ToolTalk error macro shown in Table 14–2 to check error values.
Table 14–2 ToolTalk Error Macros|
Return Type |
ToolTalk Macro |
Expands to |
Tt_status |
tt_is_err(status_code) |
The following sections describe the return value status of functions with natural return values and functions with no natural return value.
If a ToolTalk function has a natural return value such as a pointer or an integer, a special error value is returned instead of the real value.
If a ToolTalk function does not have a natural return value, the return value is an element of Tt_status enum.
To see if there is an error, use the ToolTalk macro tt_is_err, which returns an integer.
If the return value is 0, the Tt_status enum is either TT_OK
or a warning.
If the return value is 1, the Tt_status enum is an error.
If there is an error, you can use the tt_status_message function to obtain the character string that explains the Tt_status code, as shown in Example 14–1.
char *spec_id, my_application_name;
Tt_status tterr;
tterr = tt_spec_write(spec_id);
if (tt_is_err(tterr)) {
fprintf(stderr, “%s: %s\n”, my_application_name,
tt_status_message(tterr));
If an error occurs during a ToolTalk function that returns a pointer, the ToolTalk service provides an address within the ToolTalk API library that indicates the appropriate Tt_status code. To check whether the pointer is valid, you can use the ToolTalk macro tt_ptr_error. If the pointer is an error value, you can use tt_status_message to get the Tt_status character string.
Example 14–2 checks the pointer and retrieves and prints the Tt_status character string if an error value is found.
an integer, the return value is out-of-bounds. The tt_int_error
function returns a status of TT_OK
if the value is not out-of-bounds.
To check if a value is out-of-bounds, you can use the tt_is_err macro to determine if an error or a warning occurred.
To retrieve the character string for a Tt_status code, you can use tt_status_message.
Example 14–3 checks a returned integer.
The ToolTalk service provides a function to notify processes if your tool exits unexpectedly. When you include the tt_message_send_on_exit call, the ToolTalk service queues the message internally until one of two events happen:
Your process calls tt_close.
In this case, the ToolTalk service deletes the message from its queue.
The connection between the ttsession server and your process is broken; for example, the application crashed.
In this case, the ToolTalk service matches the queued message to a pattern and delivers it in the same manner as if your had sent the message normally before exiting.
Your process can also send a normal message on a normal termination by calling tt_message_send before it calls tt_close. In this case, if your process sends its normal termination message but crashes before it calls tt_close, the ToolTalk service will deliver both the normal termination message and the tt_message_send_on_exit message to interested processes.
ToolTalk functions that accept pointers always check the
pointer passed in and return TT_ERR_POINTER if the pointer is an error value. This check allows you to combine
calls in reasonable ways without checking the value of the pointer for every
single call.
In Example 14–4, a message is created, filled in, and sent. If tt_message_create fails, an error object is assigned to m, and all the tt_message_xxx_set and tt_message_send calls fail. To detect the error without checking between each call, you only need to check the return code from tt_message_send.
