When you join multiple sessions, you will automatically get responses to requests and point-to-point messages but you will not get notices unless you explicitly join the new session. The following code sample shows how to join the multiple sessions.
tt_default_session_set(new_session_identifier); tt_open(); tt_session_join(new_session); |
In order to effectively use multiple sessions, you must store the session
ids of the sessions in which you are interested in order to pass these identifiers
to tt_default_session_set prior to opening a new session
with tt_open; that is, you need to place the values (which ttsession stores in the environment variable _SUN_TT_SESSION) in a file on the system so that other ToolTalk
clients can access the value of a session id contained in that file and use
it to open the non-default session. For example, you can store the session
ids in a “well-known” file and then send a file-scoped message
(indicating this file) to all clients which have registered an appropriate
pattern. The client will then know to open the scoped-to file, read one or
more session ids from it, and use these session ids (with tt_open) to open a non-default session. An alternative method is advertising
the session ids by means of, for example, a name service or a third-party
database.
How ttsession session ids are stored and passed to interested clients is beyond the scope of the ToolTalk protocol and must be determined based on the architecture of the system.
