When you join a file, the ToolTalk service automatically adds the name
of the file to your file-scoped message patterns. For example, if you have
declared a process type or registered a message pattern that specifies TT_FILE or TT_FILE_IN_SESSION, use the tt_file_join function()
to join files of interested. Table 9–3 lists the ToolTalk functions you use to express your interest in specific
files.
Return Type |
ToolTalk Function |
Description |
char * |
tt_default_file(void) |
Join default file |
Tt_status |
tt_default_file_set(const char *docid) |
Set default file |
Tt_status |
tt_file_join(const char *filepath) |
Join this file |
Tt_status |
tt_file_quit(const char *filepath) |
Quit file |
When you no longer want to receive messages that reference the file, use the tt_file_quit() function to remove the file name from your file-scoped message patterns.
