The type TT_SESSION
scopes to a session only. Static session-scoped patterns require an explicit tt_session_join call to set the scope value; dynamic session-scoped
patterns can be set with either the tt_session_join call
or the tt_pattern_session_add call.
The session specified by these calls must be the default session.
Example 3–1 shows a static session-scoped pattern; Example 3–2 shows a dynamic session-scoped pattern.
Obtain procid |
tt_open(); |
Ptype is scoped to session |
tt_ptype_declare(ptype); |
Join session |
tt_session_join(tt_default_session()); |
Obtain procid |
tt_open(); |
Create pattern |
Tt_pattern pat = tt_create_pattern(); |
Add scope to pattern |
tt_pattern_scope_add(pat, TT_SESSION); |
Add session to pattern |
tt_pattern_session_add (tt_default_session()); |
Register pattern |
tt_pattern_register(pat); |
