The type TT_FILE_IN_SESSION scopes to the specified file in the specified session only.
A pattern with this scope set will only match messages that are scoped to
both the file and the session. Example 3–5 adds the session and then registers the pattern.
Obtain procid |
tt_open(); |
Create pattern |
Tt_pattern pat = tt_create_pattern(); |
Add scope to pattern |
tt_pattern_scope_add(pat,TT_FILE_IN_SESSION); |
Add file to pattern |
tt_pattern_file_add(pat, file); |
Add session to pattern |
tt_pattern_session_add(pat, tt_default_session()); |
Register pattern |
tt_pattern_register(pat); |
Example 3–6 registers the pattern and then joins a session.
TT_FILE_IN_SESSION-Scoped Pattern|
Obtain procid |
tt_open(); |
Create pattern |
tt_pattern_scope_add(pat, TT_FILE_IN_SESSION); |
Register pattern |
Join session |
tt_session_join(tt_default_session()); |
Example 3–7 sets the scope value for a static pattern.
TT_FILE_IN_SESSION Static Pattern|
Obtain procid |
tt_open(); |
Declare Ptype |
Tt_ptype_declare(ptype); |
Join File |
tt_file_join(file); |
Join session |
