A TT_BOTH-scoped
pattern will match messages that are scoped to the file, the session, or the
file and the session. However, when you use this scope, you must explicitly
make a tt_file_join call; otherwise, the ToolTalk service
will only match messages that are scoped to both the file and session of the
registered pattern. Example 3–8 and Example 3–9 show examples of how to use this scope.
TT_BOTH Scope|
Obtain procid |
tt_open(); |
Create pattern |
Tt_pattern pat = tt_create_pattern(); |
Add scope to pattern |
tt_pattern_scope_add(pat, TT_BOTH); |
Add session to pattern |
tt_pattern_session_add(pat,tt_default_session()); |
Add file to pattern |
tt_pattern_file_add (pat, file); |
Register pattern |
tt_pattern_register(pat); |
TT_BOTH Scope|
Obtain procid |
tt_open(); |
Declare Ptype |
Tt_ptype_declare(ptype); |
Join file |
tt_file_join(file); |
Join session |
tt_session_join(tt_default_session()); |
