This section describes how to use ToolTalk in a multi-threaded environment.
Using the ToolTalk library with multi-threaded clients requires an initialization call like the following call:
tt_feature_required(TT_FEATURE_MULTITHREADED);
The call must be invoked before any other ToolTalk call is made. Attempts
to call tt_feature_required(TT_FEATURE_MULTITHREADED)after other ToolTalk API calls have
been made will result in a TT_ERR_TOOLATE
error.
Libraries and other reusable modules that use ToolTalk might want to query the ToolTalk library to determine if the invoking application has enabled the multi-thread feature of ToolTalk. The tt_feature_enabled() API call was added for this purpose. Top-level applications rarely need to use tt_feature_enabled() since the application would know if it had already done the initialization.
When a ToolTalk client calls tt_open() or tt_session_join(), the new procid or session is the default for the thread (and not the entire process as would be the for a non-multi-threaded ToolTalk client). A thread's default procid and session, before any calls to tt_open() or tt_session_join() are made, are initially the same as the defaults for the creator of the thread. In addition to changing the defaults with tt_open() or tt_session_join(), tt_thread_procid_set() and tt_thread_session_set() can be used to switch to other defaults created previously. The default procid and session values can be retrieved using tt_thread_procid() and tt_thread_session(). The thread-specific procid and session values are managed through the use of thread-specific storage. If no value has yet been created in the thread, the default value for the entire ToolTalk process is the fallback value.
It is possible for the values returned by tt_default_procid() and tt_thread_procid() (and similarly, tt_default_session() and tt_thread_session()) to be different at any given time for some thread. This is so because tt_default_procid_set() and tt_default_session_set() do not affect the default values for a thread. They only affect the default values for the entire ToolTalk process.
Using threads with ToolTalk enabled applications is a natural implementation technique for programs that switch procids and sessions. These programs might, at some point, want to easily determine which ToolTalk procid is associated with a ToolTalk session. This was difficult to do in previous versions of ToolTalk. tt_procid_session() has been provided to accomplish this. Although tt_procid_session()does not depend on threads, it is useful for applications that use threads with ToolTalk.
tt_mark() and tt_release()affect storage allocated on a per-thread basis, not a per-process basis. Therefore, one thread cannot use tt_release() to release storage that was marked by another thread using tt_mark().
Using one thread to send a message and another to process a message is a common technique. However, use care when destroying a message with tt_message_destroy() when another thread might be examining and processing the message contents. This typically results in a program crash when the receiving thread tries to access storage that was freed by another thread. This is the same as managing non-ToolTalk storage in multi-threaded applications, but easier to do using the ToolTalk API.
