Table 8–2 describes the types of scopes that use files which you can use to scope messages with patterns.
Table 8–2 Scoping a Message with Patterns to a File|
Type of Scope |
Description |
Scopes to the specified file only. You can
set a session attribute on this type of pattern to provide a file-in-session-like
scoping but a tt_session_join call will not
update the session attribute of a pattern that is scoped to |
Scopes to the union of interest in the file and the session. A pattern with only this scope will match messages that are scoped to the file, or scoped to the session, or scoped to both the file and the session. |
Scopes to the intersection of interest in the file and the session. A pattern with only this scope will only match messages that are scoped to both the file and session. |
To scope to the union of TT_FILE_IN_SESSION and TT_SESSION,
add both scopes to the same pattern, as shown in Example 8–1.
