For some process-oriented messages, the sending application knows the ptype or the procid of the process that should handle the message. For other messages, the ToolTalk service can determine the handler from the operation and arguments of the message.
Initialize.
The sender obtains a message handle and fills in the address, scope, and class attributes.
The sender fills in the operation and arguments attributes.
If the sender has declared only one ptype, the ToolTalk service fills in sender_ptype by default; otherwise, the sender must fill it in.
If the scope is TT_FILE,
the file name must be filled in or defaulted. If the scope is TT_SESSION, the session name must be filled
in or defaulted. If the scope is TT_BOTH
or TT_FILE_IN_SESSION, both the
file name and session name must be filled in or defaulted.
The set of patterns checked for delivery depends on the scope
of the message. If the scope is TT_SESSION, only patterns for processes in the same session are checked.
If the scope is TT_FILE, patterns
for all processes observing the file are checked. If the scope is TT_FILE_IN_SESSION or TT_BOTH, both sets of processes are checked.
The sender may fill in the handler_ptype if known. However, this greatly reduces flexibility because it does not allow processes of one ptype to substitute for another. Also, the disposition attribute must be specified by the sender in this case.
Dispatch to handler.
The ToolTalk service compares the address, scope, message class, operation, and argument modes and types to all signatures in the Handle section of each ptype.
Only one ptype will usually contain a message pattern that matches the operation and arguments and specifies a handle. If a handler ptype is found, then the ToolTalk service fills in opnum, handler_ptype, and disposition from the ptype message pattern.
If the address is TT_HANDLER,
the ToolTalk service looks for the specified procid and adds the message to
the handler's message queue. TT_HANDLER
messages cannot be observed because no pattern matching is done.
Dispatch to observers.
The ToolTalk service compares the scope, class, operation, and argument types to all message patterns in the Observe section of each ptype.
For all observe signatures that match the message and specify TT_QUEUE or TT_START, the ToolTalk service attaches a record (called an “observe
promise”) to the message that specifies the ptype and the queue or start
options. The ToolTalk service then adds the ptype to its internal ObserverPtypeList.
Deliver to handler.
If a running process has a registered handler message pattern that matches the message, the ToolTalk service delivers the message to the process; otherwise, the ToolTalk service honors the disposition (start or queue) options.
If more than one process has registered a dynamic pattern that matches the handler information, the more specific pattern (determined by counting the number of non-wildcard matches) is given preference. If two patterns are equally specific, the choice of handler is arbitrary.
Deliver to observers.
The ToolTalk service delivers the message to all running processes that have registered Observer patterns that match the message. As each delivery is made, the ToolTalk service checks off any observe promise for the ptype of the observer. After this process is completed and there are observe promises left unfulfilled, the ToolTalk service honors the start and queue options in the promises.
In this example, a debugger uses an editor to display the source around a breakpoint through ToolTalk messages.
The editor has the following Handle pattern in its ptype:
(HandlerPtype: TextEditor; Op: ShowLine; Scope: TT_SESSION; Session: my_session_id; File: /home/butterfly/astrid/src/ebe.c) |
When the debugger reaches a breakpoint, it sends a message
that contains the op (ShowLine), argument (the line number), file (the file
name), session (the current session id), and scope (TT_SESSION)
attributes.
The ToolTalk service matches this message against all registered patterns and finds the pattern registered by the editor.
The ToolTalk service delivers the message to the editor.
The editor then scrolls to the line indicated in the argument.
